LM Production Settings and configuration to be import and export from Prod to Dev ?
Is there a way in Logic monitor to configure or transfer the settings and configuration available from production to Dev(Sandbox) Basically the Dev should be the replica of production but limited for testing ?
We have got a new LM sandbox(DEV), we want to configure the settings groups, Custom properties and other configuration which is configured in production to be configure in sandbox(Dev) as well ?
What is the best way to do this process? is there any import export option available ?
Vaisu86
4 comments
Kwame Armstrong
·2 years agoVaisu86
Looks like utilizing our REST API is the best option for this.
Our Professional Services team can be commissioned to help create a custom scripted solution for this task. If you are interested, you can reach out to the Customer Success Manager for your account to discuss that option.
·2 years agoYeah, you're gonna have to put/patch a ton of stuff using custom scripting from scratch.
Vaisu86
OP2 years agoKwame Armstrong
·2 years agoHello, Vaisu86 ,
From what I know, I don't believe there is an import/export for Settings, Custom properties, and other portal configurations like that. The best option that I know of would be to utilize the API but that could be a lofty task depending on the amount of items to copy over.
I will inquire internally if there are other options.
