Custom HTTP Integrations and refresh/update oauth2 tokens
Has anyone been faced with trying to create a custom http integration towards a system that need to refresh oauth2 tokens to be able to connect. The same way you need to refresh the tokens for Logic Monitor when connecting.
PeterMattsson
Posted 6 years ago·Last reply 3 years ago
4 comments
djAesthetic
·3 years agoHey @Kerry DeVilbiss -
You’d mentioned that you might have a DataSource example for performing an OAuth2 token refresh flow with an external API. I was wondering if (3 years later, to be fair) you might still have such an example?
Admittedly I may be way in over my head on this one as I am definitely an engineer (not developer) but figured I’d take a stab at borrowing some other code. Goal is simple. Authenticate to internal service, make API call for json response, spit response back out (and alert if value hits XYZ).
(Hey @RossPerez / @PeterMattsson - same question if either of you managed to get working code examples.)
Thanks either way!
RossPerez
·6 years ago@Kerry DeVilbiss,
I am trying to use this approach and it does not seem like the property token works in the http custom header value field.
Have you been able to use this approach?
Thanks
Ross
PeterMattsson
OP6 years agoThank you very much and sorry for the late response. We will surely try this.
Cheers,
Peter
Kerry DeVilbiss
·6 years agoHey @PeterMattsson,
I think we've had folks run into this before, it sounds familiar. Tokens can be used pretty extensively in a Custom HTTP Integration, so in theory, you could do something like:
Takes a little bit of work - but should get the job done. Hope that helps.
Cheers,
Kerry
