UIv4 Resources Page - Disable polling at group-level
I noticed some missing functionality in the UIv4 Resources page which I wanted to point out.
It is not currently possible to enable or disable monitoring/polling for a specific datasource at the group-level. In the old UI this used to just be a checkbox on the "Enable" row. But today I need to switch back to the old UI if I need to do that.
see below for a screenshot of this setting in the old UI. There is no equivalent to this setting in UIv4 (Enable column)
Matt Whitney
2 comments
·2 years agoI think they changed it so you still go to the Alert Tuning tab (not Inventory) and you need to choose the DataSources section to see the equivalent "collecting status" column.
Matt Whitney
OP2 years agoAh I must have missed that we had to select "Datasources" under the Alert Tuning tab. Thanks Mike!
