Hidden device group memberships
Please add an option on group objects to hide the group from being vivisble in the Alert widget's Group column.
Please see attached screen cap. I have some devices which are members of two device groups. One group (Interoute) is the business service, the other (Routers Primary) is used purely to gather all devices of a type together to run a report against. I don't want the Routers Primary group to be visible in the Alert widget Group column. A checkbox on the group object to hide from widgets would be ideal.
Mosh
2 comments
Mosh
OP9 years agoHaving group names visible in the Group column also violates the roles model. If a role does not have View rights to a group, then this group should not be visible in the Groups column either. This should be regarded a bug, I would say as it exposes something we are trying to prevent from being exposed by using roles.
Tom_Lasswell
·9 years agoI'll second this. A hide option and an option to be included as a breadcrumb group.
