Feature Request - Add Certificate Based SSH Auth to Groovy Script
I am attempting to SSH into several servers using Groovy Script, in the following manner:
import com.santaba.agent.groovyapi.expect.Expect
hostname = hostProps.get("system.hostname");
sshuser=hostProps.get("ssh.user");
sshpass=hostProps.get("ssh.pass");
cli = Expect.open(hostname,sshuser,sshpass)
Instead of logging in with a username and password, I wish to login with a client certificate instead. I reached out to LM support, and they confirmed that certificate based ssh authentication is not supported in Groovy Script.
To workaround this, I am doing this instead, where the certificate is installed on my "Jump Host":
sshjumphost=hostProps.get("ssh.jumphost");
//First, open SSH to our JumpHost
cli = Expect.open(sshjumphost,sshuser,sshpass)
//Next, execute remote ssh command on the host, from the jumphost's ssh session
cli.send("/usr/bin/ssh " + sshuser + "@" + hostname + " /home/someuser/somecommand \n")
cli.send("exit \n")
cli.expectClose()
cli.stdout().eachLine { line ->
if ( line =~ /(GOOD|ERROR) - (.*)/ ) {
println line
This works well as a workaround, but I would prefer to not have to SSH twice to get the value.
Jessie_Bryan
Hey Jared,
AFAICT, LM packages "Expect4j" which more capabilities than what we use via package com.santaba.agent.groovyapi.expect.Expect.
Some things to try:
A) Installing Expect4j on your collector, and using this library directly
B) Execute the local SSH environment of your [linux] collector. Just like you're using your jump box, except you have the collector invoke it's SSH instead (does not require Expect).
