Device graph data
Hi Team,
I used the below link to get graph data for the device (Single Instance) .
https://www.logicmonitor.com/support/rest-api-developers-guide/v1/data/get-graph-data/
Here I used the below Rest API
Here I have provided all input parameters for this URI.
But I didn't get any data for it. I was getting only "No Data" for it . But that server acutally has data .
outPut:
"data" : [ "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data", "No Data" ]
"colorName" : "green",
"std" : "NaN",
"min" : "NaN",
"max" : "NaN",
"avg" : "NaN",
"visible" : true,
"color" : "89A54E",
"legend" : "Out Unicast",
"type" : "Line",
"useYMax" : false,
"description" : "",
"label" : "OUTUNICAST",
"decimal" : -1,
"colorName" : "purple",
"std" : "NaN",
"min" : "NaN",
"max" : "NaN",
"avg" : "NaN",
"visible" : true,
"color" : "80699B",
"legend" : "In (b/m)cast",
"type" : "Line",
"useYMax" : false,
"description" : "",
"label" : "INNONUNI",
"decimal" : -1,
"colorName" : "maroon",
"std" : "NaN",
"min" : "NaN",
"max" : "NaN",
"avg" : "NaN",
"visible" : true,
"color" : "800000",
"legend" : "Out (b/m)cast",
"type" : "Line",
"useYMax" : false,
"description" : "",
"label" : "OUTNONUNI",
"decimal" : -1,
"missingLines" : [ ],
"timestamps" : [ 1555975800000, 1555976078000, 1555976378000, 1555976678000, 1555976978000, 1555977278000, 1555977578000, 1555977878000, 1555978178000, 1555978478000, 1555978778000, 1555979078000, 1555979378000, 1555979678000 ],
"scopes" : [ ],
"instances" : [ ]
Sarah Terry
·7 years ago@Soma Sekhar I think the issue here is the graph Id - in the API response you included, the graph legends do not match the legends in the image. So the graph Id in the request must not be the right one. You can make a GET request to
To see all graph Ids.
Soma_Sekhar
OP7 years ago@Sarah Terry Here is the one of the graph which I was looking .
Sarah Terry
·7 years ago@Soma Sekhar can you provide an image of the graph you're trying to get data for? It looks like the request was successful, and that the graph itself just doesn't have data.
