Built in aggregation options for Get Data APIs
I'm on hour 17 of a run of a script that pulls down Service responseTime data for about 345 services so I can come up of an average across all of those services from the last quarter.
I would love, LOVE a built-in option or parameter to aggregate this data in the API call. ![]()
Joe_Tran
2 comments
Joe_Tran
OP8 years agoHi Sarah,
As far as I know, I should be able to visualize aggregate device data using a Custom Graph widget. This is something that is lacking for Services though.
My coworkers in the business analysts teams do import LogicMonitor data into Tableau.
Joe
Sarah_Terry
·8 years agoHi Joe,
Thanks for the request - we'll look into it! Are you making this type of calculation for device datapoints as well? (e.g. averaging a key performance metric across multiple servers all supporting the same service). And is this something you'd want to visualize in a LogicMonitor dashboard widget / report, or that you're pulling into another tool? Just trying to get a bit more context re the use case :)/emoticons/smile@2x.png 2x" title=":)" width="20">
Sarah
