I’m not aware of any 4-hourly check on DataSources. We’re doing a daily index of the “in use/not in use” data (which is more advanced than running AT like v3, we actually check for instances now).
That was my datasource that ran against the unsupported /listcore endpoint and parsed out the data as datasource datapoints. I was able to add the numbers as big numbers to my main LM status dashboard and setup alerts to be notified whenever there was an update to be addressed. I’d then run my personal module toolbox script that would pull all the available updates, sort them by action needed, decode (unescape) the scripts, run the diffs with highlights, grab the histories, etc. You’ve seen that output. Unfortunately, since I can’t audit in v3 anymore, that entire workflow is broken and can’t be used anymore. So regardless of not having a date, the fact that the audit capability is gone from v3, my entire worflow is dead and I have to use the toolbox, unready as it is.
