I’m not aware of any kinda versioning or updating system for dashboards. You can import/export dashboards via json but I believe some widgets can’t be exported fully. Atleast for me, while I might first start with a built-in or github dashboard, I’ve heavily modified them for our needs. Luckily it’s easy to clone/move widgets between dashboards so I might import a new github dashboard and clone over the widgets I want, into what I’ve already have.
One option is setting up a template dashboard group with various standard dashboards you want, for each customer with some customer-based tokens. When you onboard new customers just clone the whole group. You can then focus mostly on keeping the template up-to-date and “upgrade” existing customers by replacing the old ones with the newer template ones. You still need to deal with any per-customer customization that have been made. But that is the case with a lot of things and hopefully you don’t need to do that too much.
