ldoodle
Advisor
1 year agoBrilliant, thank you.
I was looking for a way to import/update the built-in dashboards like you can with DataSources.
Is there an easy way to check the versions between what I have and what’s available on that link? Or is it a case of grabbing the ones I need now and just deleting the existing and replacing with hopefully a new one.
