for DataSources all the Datapoints must eventually result in a number, so that is true. You can write scripts or do some basic processing in LM to convert information into a number. Like converting Severity so that OK=0, Warning=1, etc. Or make a lookup table in code to convert your exception messages to codes. If you make the DataSource into a multi-instance, you will be able to create instances with custom names, descriptions and instance properties to get some of that data over but can be limited depending on what you need to store (and a bit of a hack). Getting that information out of LM into alerts and dashboards this can be hard or not possible. Also instance creation only run at-most every 15 minutes so it adds a lot of delay.You can look at the various "Troubleshooter" DataSources for examples of this trick.
DataSources would normally be used for something that has a state that you can keep querying and determine if it cleared. For example asking for free space on a drive. You can ask for the space left over and over and determine each time if that alert is active. If are looking for something like Exception event logs, they typically just have a one-time event without a start or end time. So asking over and over can't determine if the cause of the exception even cleared or not. For something like that EventSources should be used in those cases. If you do have a case where your SQL table will have no entries if there is no current exceptions (like select top 1 returns 0 rows), then DataSources would work.
You might also want to look at other features in LM (paid or otherwise), like LMConfig and LMLogs to see if those would help.
Related Content
- 15 days ago
- 11 months ago
