snmp's avatar
2 years ago
Tunnel interface monitoring in LoigicMonitor
We observed that whenever the tunnel interface changes its index ID while it reestablish, LogicMonitor is identifying it as a new interface and get it monitored. Is this an expected behavior in Logic...
  • Amr's avatar
    2 years ago
    Hi there, so that depends on the interface itself and whether it has interface index ID persistence. Interfaces that persist their index ID should remain the same prior to a reboot or status change of the interface, but they would be discovered as a new interface instance if they don't persist the interface index.
    I would recommend looking into whether the interfaces in question support index ID persistence, and enable it if possible so the interface instance remains the same after a reboot.
    If this behavior occurs on a monitored interface in your LogicMonitor portal, I would recommend reaching out to support to look into the specific case in more detail
    https://www.logicmonitor.com/support/about-logicmonitor/customer-support/get-support-resources
