Patrick_Rouse
Product Manager
2 years agoAn Enhanced Script NetScan creates the following resource group structure in the root folder of your choosing and creates the root folder if it doesn’t exist:
Meraki Org
- Meraki Network Name
If/when the names change in the Meraki Dashboard, the NetScan (if scheduled to recur) will automatically update the changes in LogicMonitor.
The Enhanced Script NetScan is 100% property and filter driven, so there is no need to edit the script to add the API key. The NetScan allows you to filter by Meraki Device Type, Network ID, or Tag.
