4 years ago
System uptime
Hi All ,
under system uptime datasource we see few instances like system uptime , uptimeDays, uptime seconds here in systemuptime i can see the static threshold set as > 85,90,95 what does th...
What you're talking about are datapoints, not instances. Instances are a different thing in LM.
To get the details on what any datapoint is, you can see the description for the datapoint once you have the datasource selected. Just go to the "Alert Tuning" tab on the right:
If I'm looking at the same one you're looking at, the Uptime datapoint is measured in 1/100ths of a second.
