Cole_McDonald
Professor
7 years agoI've lightened the load slightly on the winCertCheck (which is technically no longer the same DS as I've replaced the entirety of the scripts with simplified .NET based powershell scripts to avoid using invoke-command which tends to lead to some resource constraint issues. This should help though, will keep the same instances alive from the old code as the output is identical to the previous version by @Jonathan Arnold:
##--------------- Discovery ------------------##
$readOnly = [System.Security.Cryptography.X509Certificates.OpenFlags]"ReadOnly"
$localMachine = [System.Security.Cryptography.X509Certificates.StoreLocation]"LocalMachine"
$store = new-object System.Security.Cryptography.X509Certificates.X509Store( "\\##SYSTEM.SYSNAME##\root", $localMachine )
$store.Open( $readOnly )
$store.Certificates `
| Select-Object {$_.Thumbprint + "##" + $_.Thumbprint + "##" + $_.Subject + $_.FriendlyName} `
| Format-Table -HideTableHeaders
##-------------- Counters --------------------##
| Where-Object {($_.Thumbprint -like "##WILDVALUE##")} `
| Select-Object @{
Name = "DaysUntilExpire"
Expression = {((Get-Date -Date $_.NotAfter) - (Get-Date)).Days}
| Format-List
(please note the line continuations to help readability of the code)
As always, neither I nor Beyond Impact warranty this code. It's working in our environment, I can't guarantee it'll work in yours. This doesn't account for anything that needs credentials other than what the collector uses.
