Vitor_Santos
Expert
5 years ago2 minutes ago, Stuart Weenig said:You could create a trap listener, separate from lm, that converts the traps with their data to a log entry. Then you could create a scripted log ES to parse through the events and suppress the ones you don't want.
OID name translation has been requested before.
But that means I would've to install something at the collector level (to receives the traps & dumps them into a log entry). Right?
