thethird78
Neophyte
10 months agoReset system.sysinfo that is incorrect
I inherited maintenance of our LogicMonitor instance. There is a vCenter instance that has been there for ages that has system.sysinfo set to Microsoft Windows. This causes other things to have iss...
- 10 months ago
Sounds like a Windows vCenter install was migrated to vCenter appliance and the device wasn't redone in LM. The "proper" solution would be to remove the existing device and re-add it properly. Or "break" the existing device (change ip/dns and disable collecting) so you don't lose past performance data, before adding a new one.
If you don't want to do that, I believe there is a trick using the !hostproperty debug property to manual set the property. But that is something I would suggest working with LM support on do or atleast experimenting with a test device.
