6 years ago
Reporting APC PDU power usage
Ultimately, they want to be sure they are being billed fairly by their hosting da...
What you're seeing when you see sum/min/max/average is actually the sum of the most recent data for all instances that match your glob expression.
I'm sure you can integrate into PowerBI. Reports have CSV output option. I think you can trigger the report to gen via API then fetch the URL from which you can fetch the data.
Not sure if you're overlooking the report options, but what you see in the dialog is what you get.
