6 years ago
Reporting APC PDU power usage
Ultimately, they want to be sure they are being billed fairly by their hosting da...
36 minutes ago, Mac said:In an ideal world, id like to be able to refer to the calculated value of Watthours based on the current dashboard view time range
This is your feature request. I know it's already in the system, but you should throw your weight behind it. Every customer that requests it moves it up in priority for the Product Management team.
37 minutes ago, Mac said:Near as I can tell, there is not a way to look at the first and last value in a data range for a dashboard.. it appears to be designed to look exclusively at the most recent data values.
That's correct.
37 minutes ago, Mac said:However, the widgets are able to display a graph showing the historic data. So that makes me thinks there may be a way to reference the previous data values.
They do that because that's how those widgets are hard coded to work.
