6 years ago
Reporting APC PDU power usage
Ultimately, they want to be sure they are being billed fairly by their hosting da...
1 minute ago, Mac said:I try not to edit the data sources because that means updating them from the repository will remove my changes.
This is no longer the case thanks to the new LM Exchange. When downloading updates to a DataSource, it kicks off Save LogicModule Merge, which identifies the difference between your installed version and the updated version. Then, for each difference, you get to walk through choosing to keep your version of that setting or the exchange version of the setting.
4 minutes ago, Mac said:I guess I am asking if there is a "report designer" or maybe a means of making a gauge from this data now that I have it tracked?
Help me get a better idea of how you want to present the data. You mention gauge, does that mean you want to try to use a gauge widget?
