I would recommend looking into whether the interfaces in question support index ID persistence, and enable it if possible so the interface instance remains the same after a reboot. If this behavior occurs on a monitored interface in your LogicMonitor portal, I would recommend reaching out to support to look into the specific case in more detail https://www.logicmonitor.com/support/about-logicmonitor/customer-support/get-support-resources
Hi there, so that depends on the interface itself and whether it has interface index ID persistence. Interfaces that persist their index ID should remain the same prior to a reboot or status change of the interface, but they would be discovered as a new interface instance if they don't persist the interface index. I would recommend looking into whether the interfaces in question support index ID persistence, and enable it if possible so the interface instance remains the same after a reboot. If this behavior occurs on a monitored interface in your LogicMonitor portal, I would recommend reaching out to support to look into the specific case in more detail https://www.logicmonitor.com/support/about-logicmonitor/customer-support/get-support-resources
","kudosSumWeight":5,"repliesCount":0,"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:12803_1"},"latestVersion":null,"visibilityScope":"PUBLIC","messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[],"replies":{"__typename":"MessageConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1741988704790":{"__typename":"CachedAsset","id":"theme:customTheme1-1741988704790","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"5px","collections":["default","custom"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"LM_Community_Favicon_512x512-1733244492615.png","imageLastModified":"1733244494725","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"LogicMonitor-logo-Navy-RGB-1733509167973.png","imageLastModified":"1733509169834","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1200px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-body-color)","secondaryTextHoverColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.9))","secondaryBgColor":"#8FB5FF","secondaryBgHoverColor":"hsl(219.60000000000002, 100%, 74.9%)","secondaryBgActiveColor":"hsl(219.60000000000002, 100%, 71.8%)","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-black)","tertiaryTextHoverColor":"hsl(var(--lia-bs-black-h), var(--lia-bs-black-s), calc(var(--lia-bs-black-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-black-h), var(--lia-bs-black-s), calc(var(--lia-bs-black-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"rgba(81, 238, 239, 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid rgba(81, 238, 239, 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-body-bg)","destructiveTextHoverColor":"var(--lia-bs-body-bg)","destructiveTextActiveColor":"var(--lia-bs-body-bg)","destructiveBgColor":"var(--lia-bs-danger)","destructiveBgHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.85))","destructiveBgActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.7))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"LIGHT","radiusSm":"6px","radius":"10px","radiusLg":"18px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","forumColor":"#8FB5FF","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#2DAA0D","blogColor":"#10B2A8","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#DCDDCC","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#F5964A","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#040F4B","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#1A31FF","secondary":"#333333","bodyText":"#040F4B","bodyBg":"#FFFFFF","info":"#1A31FF","success":"#2DAA0D","warning":"#FFCC00","danger":"#D13A1F","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#51EEEF","#8FB5FF"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"DM Sans 9pt","fontStyle":"NORMAL","fontWeight":"400","h1FontSize":"34px","h2FontSize":"32px","h3FontSize":"28px","h4FontSize":"24px","h5FontSize":"20px","h6FontSize":"16px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":null,"size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","formTextMarginTop":"4px","textAreaBorderRadius":"18px","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-white)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":null,"imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"'Segoe UI', 'Helvetica Neue', Helvetica, Roboto, Arial, sans-serif","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"14px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"DM Sans 9pt","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"}],"assetNames":["DMSans9pt-normal-400.ttf","DMSans9pt-italic-400.ttf"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1741806820000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:logicmonitor.prod:pages/forums/ForumMessagePage:board:product-discussions-1741988703186":{"__typename":"CachedAsset","id":"quilt:logicmonitor.prod:pages/forums/ForumMessagePage:board:product-discussions-1741988703186","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"removeComponents":["community.widget.bannerWidget"],"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"items":[{"layout":"MAIN_SIDE","id":"message-list","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","props":{"viewVariant":{"type":"inline","props":{"useUnreadCount":false,"useViewCount":false,"renderPostTimeBeforeAuthor":true,"useSearchSnippet":false,"useAuthorLogin":true,"clampBodyLines":3,"useAvatar":true,"useBoardIcon":false,"useAuthorRank":false,"useKudosCount":false,"useMedia":false,"usePreviewMedia":false,"useTags":false,"useNode":false,"useNodeLink":true,"useTextBody":true,"truncateBodyLength":-1,"useBody":false,"useRepliesCount":false,"useSolvedBadge":true,"useTimeToRead":false,"timeStampType":"conversation.lastPostingActivityTime","useMessageTimeLink":true,"clampSubjectLines":1,"useSpoilerFreeBody":true,"useNodeHoverCard":true,"avatarSize":"40","boardIconSize":"24","subjectAs":"h6"}},"pagerVariant":{"type":"loadMore"},"panelType":"divider","pageSize":5,"useTitle":true,"sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}},"hideIfEmpty":true,"style":"compact","showTabs":false},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"},"__typename":"MainSideQuiltSection"}],"__typename":"QuiltContainer"},"__typename":"Quilt"},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1741806820000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1741806820000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:logicmonitor.prod:Common:1741988615307":{"__typename":"CachedAsset","id":"quiltWrapper:logicmonitor.prod:Common:1741988615307","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":true,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[{"children":[],"linkType":"INTERNAL","id":"Community Corner","params":{"boardId":"welcome","categoryId":"lm-pulse"},"routeName":"ForumBoardPage"},{"children":[],"linkType":"INTERNAL","id":"Customer Central","params":{"categoryId":"lm-pulse"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"Product Solutions","params":{"categoryId":"product-hub"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"Employee Discussions","params":{"boardId":"employee-discussions","categoryId":"lm-employees"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"LM Product Foundations","params":{"categoryId":"lm-foundations"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"ai-basics-course-discussions-link","params":{"categoryId":"ai-basics-course-discussions"},"routeName":"CategoryPage"}],"linkType":"INTERNAL","id":"Employee Engage","params":{"categoryId":"lm-employees"},"routeName":"CategoryPage"}],"mainLinks":[{"children":[{"linkType":"INTERNAL","id":"LM Exchange","params":{"boardId":"lm-exchange","categoryId":"product-hub"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Product Discussions","params":{"boardId":"product-discussions","categoryId":"product-hub"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Feature Requests","params":{"boardId":"feature-requests","categoryId":"product-hub"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Technical Communications","params":{"boardId":"technical-commmunications","categoryId":"product-hub"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Open Beta Group","params":{"groupHubId":"open-beta"},"routeName":"GroupHubPage"},{"linkType":"INTERNAL","id":"Archive","params":{"boardId":"archive","categoryId":"product-hub"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"Product Solutions","params":{"categoryId":"product-hub"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"Welcome to LM Community!","params":{"boardId":"welcome","categoryId":"lm-pulse"},"routeName":"ForumBoardPage"},{"linkType":"EXTERNAL","id":"Common-external-link","url":"https://community.logicmonitor.com/tag/Best%20practices%20for%20practitioners?nodeId=board%3Atech-talk","target":"BLANK"},{"linkType":"INTERNAL","id":"Tech Talk","params":{"boardId":"tech-talk","categoryId":"lm-pulse"},"routeName":"BlogBoardPage"},{"linkType":"INTERNAL","id":"LM News","params":{"boardId":"lm-news","categoryId":"lm-pulse"},"routeName":"BlogBoardPage"},{"linkType":"INTERNAL","id":"Customer Onboarding","params":{"boardId":"customer-onboarding","categoryId":"lm-pulse"},"routeName":"ForumBoardPage"},{"linkType":"EXTERNAL","id":"LM Academy Portal","url":"https://academy.logicmonitor.com","target":"SELF"}],"linkType":"INTERNAL","id":"Customer Central","params":{"categoryId":"lm-pulse"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"lm-training-live","params":{"groupHubId":"lm-training-live"},"routeName":"GroupHubPage"},{"linkType":"INTERNAL","id":"Common-events-link","params":{"boardId":"events","categoryId":"top"},"routeName":"EventBoardPage"},{"linkType":"INTERNAL","id":"Inner Circle - Customer Advocacy","params":{"groupHubId":"inner-circle"},"routeName":"GroupHubPage"},{"linkType":"EXTERNAL","id":"Community Help - Login","url":"https://community.logicmonitor.com/discussions/community-feedback/community-login-issues/15477","target":"BLANK"},{"linkType":"INTERNAL","id":"Community Feedback","params":{"boardId":"community-feedback","categoryId":"lm-pulse"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"Community Corner","params":{"boardId":"welcome","categoryId":"lm-pulse"},"routeName":"ForumBoardPage"},{"children":[],"linkType":"INTERNAL","id":"events","params":{"boardId":"events","categoryId":"top"},"routeName":"EventBoardPage"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"hsla(30, 100%, 50%)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"14px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"30px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"15px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"var(--lia-bs-body-color)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-dark)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-body-color)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"2px solid var(--lia-bs-primary)","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"15px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-primary)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-primary)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"transparent","visualEffects":{"showBottomBorder":true},"backgroundOpacity":70,"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-body-color)"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"var(--lia-bs-body-bg)","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":false},"backgroundOpacity":100,"linkTextColor":"var(--lia-bs-gray-700)"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":"footer.png","backgroundSize":"CONTAIN","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":"1733509816000","__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1741806820000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1741806820000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1741806820000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1741806820000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1741806820000","value":{"title@userScope:other":"Recent Content","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Recent Discussions","title@board:BLOG@userScope:other":"Recent Blogs","emptyDescription":"No content to show","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Scope","title@instance:1711369335300":"","title@instance:goCfUH":"What's Happening @LM?","title@instance:1713795011144":"Recent Content","title@instance:BHIzON":"Questions? Ask Here!","title@instance:1711640146061":"Questions? Ask Here!","title@instance:uaopJa":"Questions? Ask Here!","title@instance:MmIpBT":"","title@instance:1711544340591":"Ask Questions Here!","title@instance:ZzjYpi":"Ask Questions Here!","title@instance:dFsNGW":"Community Engagement Activity","title@instance:1713449345071":"Job Discussions","title@instance:1715202029000":"Discussions"},"localOverride":false},"CachedAsset:text:en_US-components/community/FooterWidget-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/FooterWidget-1741806820000","value":{"homeLink":"Community Home","topOfPage":"Top of Page","buildHash":"Build Hash:","buildNumber":"Build Number:","buildTime":"Build Time:","privacyPolicy":"Privacy Policy","helpLink":"Help"},"localOverride":false},"Forum:board:feature-requests":{"__typename":"Forum","id":"board:feature-requests","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:lm-exchange":{"__typename":"Forum","id":"board:lm-exchange","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"FORUM","displayId":"lm-exchange","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"LM Exchange","shortTitle":"LM Exchange","parent":{"__ref":"Category:category:product-hub"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":true,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.logicmonitor.com/t5/s/ajkuw86572/images/bi0xMy1GS0Q0bEI?image-coordinates=0%2C0%2C250%2C250\"}"},"description":"Unlock the full potential of your LogicMonitor platform with the LM Exchange forum. Discover a wealth of integrations, scripts, and customizations created by the community and LogicMonitor experts. Dive into discussions, share your own contributions, and collaborate with peers to extend the functionality of your monitoring environment. Explore, innovate, and elevate your monitoring experience with the LM Exchange forum today.","eventPath":"category:product-hub/community:ajkuw86572board:lm-exchange/"},"Forum:board:archive":{"__typename":"Forum","id":"board:archive","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:tech-talk":{"__typename":"Blog","id":"board:tech-talk","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"GroupHub:grouphub:open-beta":{"__typename":"GroupHub","id":"grouphub:open-beta","grouphubPolicies":{"__typename":"GroupHubPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:lm-pulse":{"__typename":"Category","id":"category:lm-pulse","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:welcome":{"__typename":"Forum","id":"board:welcome","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:lm-news":{"__typename":"Blog","id":"board:lm-news","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"GroupHub:grouphub:inner-circle":{"__typename":"GroupHub","id":"grouphub:inner-circle","grouphubPolicies":{"__typename":"GroupHubPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:community-feedback":{"__typename":"Forum","id":"board:community-feedback","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:customer-onboarding":{"__typename":"Forum","id":"board:customer-onboarding","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Occasion:board:events":{"__typename":"Occasion","id":"board:events","boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"occasionPolicies":{"__typename":"OccasionPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Conversation:conversation:18112":{"__typename":"Conversation","id":"conversation:18112","topic":{"__typename":"ForumTopicMessage","uid":18112},"lastPostingActivityTime":"2025-03-14T13:16:40.275-07:00","solved":false},"ForumTopicMessage:message:18112":{"__typename":"ForumTopicMessage","subject":"Can LM verify a server's time is correct?","conversation":{"__ref":"Conversation:conversation:18112"},"id":"message:18112","revisionNum":1,"uid":18112,"depth":0,"board":{"__ref":"Forum:board:product-discussions"},"author":{"__typename":"User","uid":4456,"login":"Kelemvor","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":null}},"metrics":{"__typename":"MessageMetrics","views":73},"postTime":"2025-03-13T14:35:13.294-07:00","lastPublishTime":"2025-03-13T14:35:13.294-07:00","readOnly":false},"Conversation:conversation:16254":{"__typename":"Conversation","id":"conversation:16254","topic":{"__typename":"ForumTopicMessage","uid":16254},"lastPostingActivityTime":"2025-03-14T08:33:10.650-07:00","solved":false},"ForumTopicMessage:message:16254":{"__typename":"ForumTopicMessage","subject":"Option to remove Resource descriptions from Resource Tree","conversation":{"__ref":"Conversation:conversation:16254"},"id":"message:16254","revisionNum":1,"uid":16254,"depth":0,"board":{"__ref":"Forum:board:product-discussions"},"author":{"__typename":"User","uid":21,"login":"David_Bond","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.logicmonitor.com/t5/s/ajkuw86572/images/dS0yMS1sYkxzZmY?image-coordinates=0%2C0%2C996%2C996"}},"metrics":{"__typename":"MessageMetrics","views":29},"postTime":"2024-08-19T09:35:43.396-07:00","lastPublishTime":"2024-08-19T09:35:43.396-07:00","readOnly":false},"Conversation:conversation:18102":{"__typename":"Conversation","id":"conversation:18102","topic":{"__typename":"ForumTopicMessage","uid":18102},"lastPostingActivityTime":"2025-03-14T05:32:57.865-07:00","solved":false},"ForumTopicMessage:message:18102":{"__typename":"ForumTopicMessage","subject":"Get all instances WildValues from under particular Datasource - Powershell script","conversation":{"__ref":"Conversation:conversation:18102"},"id":"message:18102","revisionNum":1,"uid":18102,"depth":0,"board":{"__ref":"Forum:board:product-discussions"},"author":{"__typename":"User","uid":6173,"login":"WRKMC","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.logicmonitor.com/t5/s/ajkuw86572/m_assets/avatars/default/avatar-12.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":60},"postTime":"2025-03-13T03:56:46.422-07:00","lastPublishTime":"2025-03-13T03:56:46.422-07:00","readOnly":false},"Conversation:conversation:18104":{"__typename":"Conversation","id":"conversation:18104","topic":{"__typename":"ForumTopicMessage","uid":18104},"lastPostingActivityTime":"2025-03-13T09:10:19.743-07:00","solved":true},"ForumTopicMessage:message:18104":{"__typename":"ForumTopicMessage","subject":"LM SDK API v3 - get_device_list not responding","conversation":{"__ref":"Conversation:conversation:18104"},"id":"message:18104","revisionNum":1,"uid":18104,"depth":0,"board":{"__ref":"Forum:board:product-discussions"},"author":{"__typename":"User","uid":6052,"login":"llama","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.logicmonitor.com/t5/s/ajkuw86572/m_assets/avatars/default/avatar-4.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":44},"postTime":"2025-03-13T05:16:52.708-07:00","lastPublishTime":"2025-03-13T05:16:52.708-07:00","readOnly":false},"Conversation:conversation:18007":{"__typename":"Conversation","id":"conversation:18007","topic":{"__typename":"ForumTopicMessage","uid":18007},"lastPostingActivityTime":"2025-03-13T07:12:33.901-07:00","solved":false},"ForumTopicMessage:message:18007":{"__typename":"ForumTopicMessage","subject":"UIv4 LogicModule Descriptions","conversation":{"__ref":"Conversation:conversation:18007"},"id":"message:18007","revisionNum":1,"uid":18007,"depth":0,"board":{"__ref":"Forum:board:product-discussions"},"author":{"__typename":"User","uid":3582,"login":"Justin_Lanoue","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":null}},"metrics":{"__typename":"MessageMetrics","views":67},"postTime":"2025-03-05T06:11:44.501-08:00","lastPublishTime":"2025-03-05T06:11:44.501-08:00","readOnly":false},"AssociatedImage:{\"url\":\"https://community.logicmonitor.com/t5/s/ajkuw86572/images/cmstMjYtamhHWVBP\"}":{"__typename":"AssociatedImage","url":"https://community.logicmonitor.com/t5/s/ajkuw86572/images/cmstMjYtamhHWVBP","height":220,"width":1140,"mimeType":"image/png"},"Rank:rank:26":{"__typename":"Rank","id":"rank:26","position":27,"name":"Neophyte","color":"333333","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.logicmonitor.com/t5/s/ajkuw86572/images/cmstMjYtamhHWVBP\"}"},"rankStyle":"TEXT"},"User:user:5341":{"__typename":"User","id":"user:5341","uid":5341,"login":"acampbell78","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-09-18T09:02:29.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":null},"rank":{"__ref":"Rank:rank:26"},"messagesCount":11,"kudosGivenCount":17,"kudosReceivedCount":71,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ajkuw86572/user:5341"},"ForumTopicMessage:message:14380":{"__typename":"ForumTopicMessage","uid":14380,"subject":"Monitoring interface ports on a network switch","id":"message:14380","revisionNum":1,"repliesCount":5,"author":{"__ref":"User:user:5341"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:product-discussions"},"conversation":{"__ref":"Conversation:conversation:14380"},"moderationData":{"__ref":"ModerationData:moderation_data:14380"},"postTime":"2024-01-05T03:09:16.000-08:00","lastPublishTime":"2024-01-05T03:09:16.000-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":586},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:product-hub/community:ajkuw86572board:product-discussions/message:14380"},"Conversation:conversation:14380":{"__typename":"Conversation","id":"conversation:14380","solved":true,"topic":{"__ref":"ForumTopicMessage:message:14380"},"lastPostingActivityTime":"2024-01-09T12:14:03.000-08:00","lastPostTime":"2024-01-09T12:14:03.000-08:00"},"ModerationData:moderation_data:14380":{"__typename":"ModerationData","id":"moderation_data:14380","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:14380":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:14380","relatedMessage":{"__ref":"ForumTopicMessage:message:14380"}},"ForumTopicMessage:message:13980":{"__typename":"ForumTopicMessage","uid":13980,"subject":"How to you setup a monitor for monitoring outside interface on a firewall","id":"message:13980","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:5341"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:product-discussions"},"conversation":{"__ref":"Conversation:conversation:13980"},"moderationData":{"__ref":"ModerationData:moderation_data:13980"},"postTime":"2023-10-26T00:19:26.000-07:00","lastPublishTime":"2023-10-26T00:19:26.000-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":79},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:product-hub/community:ajkuw86572board:product-discussions/message:13980"},"Conversation:conversation:13980":{"__typename":"Conversation","id":"conversation:13980","solved":true,"topic":{"__ref":"ForumTopicMessage:message:13980"},"lastPostingActivityTime":"2023-10-26T06:08:29.000-07:00","lastPostTime":"2023-10-26T06:08:29.000-07:00"},"ModerationData:moderation_data:13980":{"__typename":"ModerationData","id":"moderation_data:13980","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:13980":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:13980","relatedMessage":{"__ref":"ForumTopicMessage:message:13980"}},"User:user:5420":{"__typename":"User","id":"user:5420","uid":5420,"login":"phakesley","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-11-15T00:52:41.000-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":null},"rank":{"__ref":"Rank:rank:26"},"messagesCount":10,"kudosGivenCount":0,"kudosReceivedCount":26,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ajkuw86572/user:5420"},"ForumTopicMessage:message:17618":{"__typename":"ForumTopicMessage","uid":17618,"subject":"SNMP Interface Naming","id":"message:17618","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:5420"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:product-discussions"},"conversation":{"__ref":"Conversation:conversation:17618"},"moderationData":{"__ref":"ModerationData:moderation_data:17618"},"postTime":"2025-01-27T06:45:45.680-08:00","lastPublishTime":"2025-01-27T06:45:45.680-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":115},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:product-hub/community:ajkuw86572board:product-discussions/message:17618"},"Conversation:conversation:17618":{"__typename":"Conversation","id":"conversation:17618","solved":false,"topic":{"__ref":"ForumTopicMessage:message:17618"},"lastPostingActivityTime":"2025-01-27T12:24:47.273-08:00","lastPostTime":"2025-01-27T12:24:47.273-08:00"},"ModerationData:moderation_data:17618":{"__typename":"ModerationData","id":"moderation_data:17618","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:17618":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:17618","relatedMessage":{"__ref":"ForumTopicMessage:message:17618"}},"User:user:3582":{"__typename":"User","id":"user:3582","uid":3582,"login":"Justin_Lanoue","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-10-04T11:44:37.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":null},"rank":{"__ref":"Rank:rank:26"},"messagesCount":29,"kudosGivenCount":1,"kudosReceivedCount":98,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":2,"entityType":"USER","eventPath":"community:ajkuw86572/user:3582"},"ForumTopicMessage:message:14445":{"__typename":"ForumTopicMessage","uid":14445,"subject":"How is everyone else handling network interface ID changes?","id":"message:14445","revisionNum":1,"repliesCount":3,"author":{"__ref":"User:user:3582"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:product-discussions"},"conversation":{"__ref":"Conversation:conversation:14445"},"moderationData":{"__ref":"ModerationData:moderation_data:14445"},"postTime":"2024-01-23T06:44:22.000-08:00","lastPublishTime":"2024-01-23T06:44:22.000-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":249},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:product-hub/community:ajkuw86572board:product-discussions/message:14445"},"Conversation:conversation:14445":{"__typename":"Conversation","id":"conversation:14445","solved":true,"topic":{"__ref":"ForumTopicMessage:message:14445"},"lastPostingActivityTime":"2024-01-23T07:19:05.000-08:00","lastPostTime":"2024-01-23T07:19:05.000-08:00"},"ModerationData:moderation_data:14445":{"__typename":"ModerationData","id":"moderation_data:14445","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:14445":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:14445","relatedMessage":{"__ref":"ForumTopicMessage:message:14445"}},"User:user:6022":{"__typename":"User","id":"user:6022","uid":6022,"login":"tk_baha","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-11-13T14:44:29.906-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.logicmonitor.com/t5/s/ajkuw86572/m_assets/avatars/default/avatar-4.svg?time=0"},"rank":{"__ref":"Rank:rank:26"},"messagesCount":5,"kudosGivenCount":1,"kudosReceivedCount":6,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ajkuw86572/user:6022"},"AssociatedImage:{\"url\":\"https://community.logicmonitor.com/t5/s/ajkuw86572/images/bi0xMy1GS0Q0bEI?image-coordinates=0%2C0%2C250%2C250\"}":{"__typename":"AssociatedImage","url":"https://community.logicmonitor.com/t5/s/ajkuw86572/images/bi0xMy1GS0Q0bEI?image-coordinates=0%2C0%2C250%2C250","mimeType":"image/png"},"ForumTopicMessage:message:17837":{"__typename":"ForumTopicMessage","uid":17837,"subject":"Monitoring of Veeam is not reliable","id":"message:17837","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:6022"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:lm-exchange"},"conversation":{"__ref":"Conversation:conversation:17837"},"moderationData":{"__ref":"ModerationData:moderation_data:17837"},"postTime":"2025-02-05T16:48:38.963-08:00","lastPublishTime":"2025-02-05T16:48:38.963-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":144},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:product-hub/community:ajkuw86572board:lm-exchange/message:17837"},"Conversation:conversation:17837":{"__typename":"Conversation","id":"conversation:17837","solved":true,"topic":{"__ref":"ForumTopicMessage:message:17837"},"lastPostingActivityTime":"2025-02-06T12:34:19.101-08:00","lastPostTime":"2025-02-06T12:34:19.101-08:00"},"ModerationData:moderation_data:17837":{"__typename":"ModerationData","id":"moderation_data:17837","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:17837":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:17837","relatedMessage":{"__ref":"ForumTopicMessage:message:17837"}},"CachedAsset:text:en_US-components/community/Navbar-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1741806820000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","Tech Talk":"Community Blog and Product Insights","external-1":"LM Training LIVE!","external":"Product Roadmap Roadshow","LM News":"LM Community News ","Customer User Groups":"LM User Groups","lm-training-live":"LM Training | LIVE ","Community Corner":"Customer Programs","ai-basics-course-discussions-link":"AI Basics Course Discussions","Common-external-link":"Best Practices for Practitioners","Product Solutions":"Tech Forums","Common-events-link":"LM User Groups","events":"Events"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1741806820000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1741806820000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1741806820000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1741806820000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1741806820000","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1741806820000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1741806820000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solved","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageDeepLink-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageDeepLink-1741806820000","value":{"viewFullDiscussion@board:FORUM":"View Full Discussion ({repliesCount} Replies)","viewFullDiscussion@board:BLOG":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:TKB":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:IDEA":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:OCCASION":"View Full Discussion ({repliesCount} Comments)","showParents@board:FORUM":"Show Parent Replies","showParents@board:BLOG":"Show Parent Comments","showParents@board:TKB":"Show Parent Comments","showParents@board:IDEA":"Show Parent Comments","showParents@board:OCCASION":"Show Parent Comments"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1741806820000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1741806820000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/BuildInformation-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/BuildInformation-1741806820000","value":{"buildHash":"Build Hash: {buildHash}","buildNumber":"Build Number: {buildNumber}","buildTime":"Build Time: {buildTime}"},"localOverride":false},"CachedAsset:text:en_US-components/community/KhorosLogo-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/KhorosLogo-1741806820000","value":{"alt":"Powered By Khoros"},"localOverride":false},"QueryVariables:MessageSolutions":{"__typename":"QueryVariables","id":"MessageSolutions","value":{"first":10,"constraints":{"topicId":{"eq":"message:12802"},"solution":{"eq":true}},"sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":false,"useBody":true,"useKudosCount":false,"useTimeToRead":false,"useMedia":true,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":true,"useTags":false,"useUserHoverCard":false,"useNodeHoverCard":false,"usePreviewSubjectModal":false,"useMessageStatus":false}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1741806820000","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1741806820000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1741806820000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1741806820000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1741806820000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1741806820000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1741806820000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1741806820000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1741806820000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1741806820000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolutionList-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolutionList-1741806820000","value":{"emptyDescription":"No has been message solutions yet"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1741806820000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMore-1741806820000","value":{"loadMore":"Show More"},"localOverride":false},"User:user:2670":{"__typename":"User","id":"user:2670","uid":2670,"login":"Amr","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2021-07-30T09:05:03.000-07:00","confirmEmailStatus":null},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.logicmonitor.com/legacyfs/online/avatars/cc7b3868-e688-4c96-978c-5d507f6523ce.png"},"entityType":"USER","eventPath":"community:ajkuw86572/user:2670","rank":{"__ref":"Rank:rank:4"},"messagesCount":26,"topicsCount":1,"kudosReceivedCount":99,"kudosGivenCount":218,"kudosWeight":1,"followersCount":null,"solutionsCount":5},"ModerationData:moderation_data:12803":{"__typename":"ModerationData","id":"moderation_data:12803","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"AssociatedImage:{\"url\":\"https://community.logicmonitor.com/t5/s/ajkuw86572/images/cmstNC1lQzdPMmw\"}":{"__typename":"AssociatedImage","url":"https://community.logicmonitor.com/t5/s/ajkuw86572/images/cmstNC1lQzdPMmw","height":220,"width":1140,"mimeType":"image/png"},"Rank:rank:4":{"__typename":"Rank","id":"rank:4","position":3,"name":"LM Champion","color":"333333","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.logicmonitor.com/t5/s/ajkuw86572/images/cmstNC1lQzdPMmw\"}"},"rankStyle":"TEXT"},"Revision:revision:12803_1":{"__typename":"Revision","id":"revision:12803_1","lastEditTime":"2023-05-30T07:56:59.000-07:00"},"QueryVariables:ReplyList:message:12803:1":{"__typename":"QueryVariables","id":"ReplyList:message:12803:1","value":{"id":"message:12803","first":10,"sorts":{"kudosSumWeight":{"direction":"DESC","order":0},"postTime":{"direction":"ASC","order":1}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"kudosSumWeight":{"direction":"DESC","order":0},"postTime":{"direction":"ASC","order":1}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1741806820000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1741806820000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1741806820000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1741806820000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeIcon-1741806820000","value":{"contentType":"Content Type {style, select, FORUM {Forum} BLOG {Blog} TKB {Knowledge Base} IDEA {Ideas} OCCASION {Events} other {}} icon"},"localOverride":false},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1741806820000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1741806820000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"product-discussions","messageSubject":"tunnel-interface-monitoring-in-loigicmonitor","messageId":"12802","replyId":"12803"},"buildId":"G6LFdF6Y8sb5g8rZyM3sC","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"logicmonitor","openTelemetryServiceVersion":"25.2.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/messages/MessageListForNodeByRecentActivityWidget/MessageListForNodeByRecentActivityWidget.tsx","./components/community/FooterWidget/FooterWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/community/FooterWidgetHelpLink/FooterWidgetHelpLink.tsx","./components/community/KhorosLogo/KhorosLogo.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","../shared/client/components/common/List/ListGroup/ListGroup.tsx","../shared/client/components/common/Pager/PagerLoadMore/PagerLoadMore.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx"],"appGip":true,"scriptLoader":[]}
