2 years ago
Test Groovy script on a device
Hello All, Newbie here! Can anyone please tell me how to test a groovy script in a particular device? I have found that there is a debug command option for the collector. But how I do set the devi...
- 2 years ago
You can use the chrome extension here:
https://chrome.google.com/webstore/detail/logicmonitor-script-debug/ijojgoccfeggejpbhdahmeijjhpdjklf
It adds additional functionality to the !groovy debug function, one of those being a drop down on the top right side that allows you to specify the host you are running the script against. As Mike mentioned above, the source will be the collector you have opened the collector debug facility from.
