4 years ago
Reporting APC PDU power usage
Ultimately, they want to be sure they are being billed fairly by their hosting da...
16 hours ago, Stuart Weenig said:What you're seeing when you see sum/min/max/average is actually the sum of the most recent data for all instances that match your glob expression.
I'm sure you can integrate into PowerBI. Reports have CSV output option. I think you can trigger the report to gen via API then fetch the URL from which you can fetch the data.
Not sure if you're overlooking the report options, but what you see in the dialog is what you get.
Thanks Stuart
I really dont want to use an external system for this, but it sounds like we have run this as far as we can with Logic Monitor reporting and widgets.
I looked through the feature requests as you mentioned before and I couldnt find anything that sounded like this. So I submitted as new one and figured they could be joined if the other one pops up.
Thank you again for all of your help
