4 years ago
Reporting APC PDU power usage
Ultimately, they want to be sure they are being billed fairly by their hosting da...
I was tinkering with the big number widget and looks like it "could" do this. However, it is displaying Resource not found
I tried using sum, min and max from the new watthour complex datpoint and from the snmp raw value
its seems like this is right at the cusp of working..... so frustrating :)/emoticons/smile@2x.png 2x" title=":)" width="20" />
So if a widget is not possible, is there a way to create a Resource Metric Trend Report with a custom configuration?
being able to adjust Column titles, the data scaling and data labels would make this almost usable for a client facing report.
If a custom report solution isnt an option, is there a way to integrate to PowerBI?
