5 years ago
1 hour ago, Stuart Weenig said:You could create a service out of those two links. The service metric would be interface status. You would choose to aggregate the status data by "mean". If both links are up, they'd both return 1, so the average would be 1. If one link is down, you'd get the average of 1 and 2 (1.5). If both links are down, you'd average 2 and 2 (2). Set your threshold to >=2 and you should be good to go.
The only tedious part is setting this up for each pair of links you have.
This sounds perfect! Thank you for the suggestion!
I put the 2 instances I want to monitor together and made a rule for it. Just need to test it and see if it works as intended.
