7 months ago
Hi Admine,
thank you for this hint. Do you have a link to any documentation about this? Or is it a undocumented feature?
I have been checking https://www.logicmonitor.com/support/rest-api-v3-swagger-documentation, but no luck.
- Admine7 months ago
Neophyte
Hi Jeroen,
Yes its not in the documentation as far as i know. But i think you can use the endpoint described in the swagger documentation and then any payload as long as its in the format of the payload described above.
