Hi Austin! My name is Bowen. I'm a PM at LogicMonitor and oversee our APM product development.
First, awesome to hear that you made it out to our Elevate conference earlier this month. Second, I'm stoked to hear that you're interested in trying out OpenTelemetry/LM APM. Here is a sample application from Google that we use internally that you can also run to try out APM: https://github.com/logicmonitor/hipster#readme
Alternatively, depending on your level of comfort, we have a number of technical blogs available that walk you through how to set up and instrument a sample application. Here is an example in Flask: https://www.logicmonitor.com/blog/flask-application-manual-instrumentation-for-distributed-traces
I'll connect with our teams internally to make sure APM access is enabled in your portal. Thanks!
