16 minutes ago, mnagel said:The only NX-OS flow data we have functioning is via sflow not netflow, but both ought to work. Unfortunately, the documentation is a bit limited -- improved since the old days, but there is only one example -- the very popular and modern Cisco 3745 router with original Netflow. LM should have a maintained library of examples.
Regardless, the required field list is there (assuming the documentation is accurate). If you can't define a suitable record, get a capture and open a support case with LM to find out what changes to the record are needed to make it work.
Yeah, that one surprised me too. The TAC seemed to have no ready examples available. I do have a ticket open for this now.
It was showing in the debug console as data coming in, but no templates showing up.
$ !netflow func=listdevices
ID Name Interface Indx IP Addresses
11653 10.35.253.6 10.0.0.6, 10.35.0.174, 10.0.0.18, 10.35.252.2, 10.35.253.6, 10.36.0.13, 10.35.0.97, 10.35.0.105, 10.35.0.110, 10.35.0.74, 10.35.0.81, 10.35.0.89
11984 10.35.254.33 10.35.254.33, 38.32.89.58, 204.48.44.3, 204.48.45.3 <- non working 4451 that has to use a VRF for management.. prolly my bad.
11655 10.35.253.5 10.0.0.2, 10.35.0.170, 10.35.252.1, 10.35.253.5, 10.36.0.9, 10.35.0.109, 10.35.0.73, 10.35.0.77, 10.35.0.85, 10.35.0.93 <- nexus 7004
11987 10.35.253.2 9,4,1,2,0 10.35.0.169, 10.35.0.173, 10.35.252.3, 10.35.253.2, 10.78.7.173 <- Working 4451
11985 10.35.253.1 3,1,0,2 204.48.44.50, 204.48.44.55, 10.35.253.1, 10.35.252.5, 192.168.7.5, 204.48.44.14, 10.35.0.86, 10.35.0.90 <- working 4451
11991 10.35.253.9 10.35.253.9, 10.35.0.98, 10.1.15.253, 10.35.0.94
11981 10.35.254.32 10.35.254.32, 50.218.62.74, 204.48.44.1, 204.48.45.1, 204.48.44.2, 204.48.45.2 <- non working 4451 that has to use a VRF for management.. prolly my bad.
