Professor
4 years agoThe only NX-OS flow data we have functioning is via sflow not netflow, but both ought to work. Unfortunately, the documentation is a bit limited -- improved since the old days, but there is only one example -- the very popular and modern Cisco 3745 router with original Netflow. LM should have a maintained library of examples.
Regardless, the required field list is there (assuming the documentation is accurate). If you can't define a suitable record, get a capture and open a support case with LM to find out what changes to the record are needed to make it work.
