Stuart_Weenig
5 months agoLegend
Yeah, the configsource is running at regular intervals. What you see in the UI are the versions of the config. If the version of the config it fetches right now matches the version you already have, no need to keep it in LM.
Check the “Last Checked” and “Last Updated’ timestamps.
- Last Checked is the last time LM went to the device and grabbed the config.
- Las Updated is the last time the config changed.
