Vijay's avatar
Vijay
8 years ago
Monitor IBM DB2 using LogicMonitor
I  need some advise on how to monitor specific DB2 parameters through LogicMonitor
The parameters that has to be brought under the monitoring purview is as shown below :
Database status
Database backup status
Table space check
EPOS transaction data check
Check SVOC data
Number of queries running at a time
Long running queries
Locks
Any performance issue
Job status check
No of users/sessions logged in
  • David_Lee's avatar
    David_Lee
    Former Employee
    There is a sample jdbc datasource for DB2 available, if you would like to contact support, they can have it installed into your account. Once you do so you just have to add the queries you want and and valid datapoints.
  • Hi,
    Do we have a list on what parameters are included on IBM DB2 monitoring from Logicmonitor ?
    Regards,
    Vinodh
