fishizza's avatar
5 months ago
Monitor a running .exe
We have a need to monitor if a particular .exe is running on a windows system.  So if you were to go into task manager and just look for whether it was running or not (e.g. task.exe exists).  Seems p...
  • fishizza's avatar
    4 months ago
    I found a workaround outside of LogicMon.  Would be nice if this worked.
