6 years ago
Missing JDBC connection string
	I have recently seen a few of these tickets com across the board and was wondering if anyone would be able to give me a quick breakdown as to what this actually is and what the benefit...
There is a "troubleshooter" DataSource that checks servers that appear to be MSSQL servers to see if LM has the credentials necessary to log into that SQL server. In this case, LM thinks the server is a MSSQL server, but cannot log into the MSSQL instance. If you don't want to monitor this MSSQL server, there are several options for disabling the troubleshooter DS. If you do want to monitor them, you'll need to add the MSSQL credentials so that LM can log into the MSSQL instance and monitor it with the out of the box MSSQL DataSources.
