Proxy Server is referring to a possible system or server(s) that provides you with access to the web. It would be something your company would be running within your environment and nothing at LogicMonitor. It's pretty rare these days and if you are not already aware of one, you are likely not using one.
I would guess the Collector asked for it because it wasn't able to reach the LogicMonitor portal. You should make sure that the server you have the collector on is able to reach your LogicMonitor portal at https://yourportal.logicmonitor.com in a browser. Also make sure that server meets the requirements per https://www.logicmonitor.com/support/collectors/collector-installation/installing-collectors#requirements-for-collector-servers
Also see https://www.logicmonitor.com/blog/my-collector-is-down-troubleshoot-in-6-steps
If you need to whitelist access to the LogicMonitor Portal, the details are at https://www.logicmonitor.com/support/about-logicmonitor/overview/logicmonitor-public-ip-addresses-dns-names
If you need more specific help or someone to look at your portal, I would suggest reaching out to LM support.
Indeed, awesome explanation. This should be the support doc.
- mray1 year ago
LM Conqueror
Agreed! I'll submit a ticket for that.
Right now, this info is all kinda displaced across a few pages:
https://www.logicmonitor.com/support/collectors/collector-overview/about-the-logicmonitor-collector
https://www.logicmonitor.com/support/collectors/collector-configurations/configuring-your-collector-for-use-with-http-proxiesA more concise mention in the install doc would be best for sure.
