Skeer's avatar
Skeer
9 months ago
Integration - Custom HTTP Delivery issues with AWS NLB
Ok so I'm trying to setup a custom http delivery to an Event-Driven Ansible webhook. The EDA target is in AWS behind a network load balancer where SSL terminates on the ec2. For sake of argument let's assume everything on the AWS side has been done; sec group with LM's public IP's, no bad NACLs, NLB is interface-facing, public DNS is good, etc.
So I can test the webhook using curl from an internal and external host, and it's successful!
But testing from LM ends in nothing but a request timed out.
I do not know if it's TLS/SSL related..
Is it DNS? Like can LM correctly resolve my fqdn?
Is it some LB attribute like preserve client ip's?
Here is the URL in question, sanitized:
https://ansible.domain.com/eda-event-streams/api/eda/v1/external_event_stream/630729f0-702d-4b66-8e77-66f12b923fb0/post/
I did set the method to POST, included the user and passwd and a very simple Raw payload of {"message": "HELLO"}
  • I might not have been super clear earlier.. so the only way I am able to test this right now is using the Test Alert Delivery function. I know there's ways to return data in the HTTP response but I am nowhere near being able to do that right now.
    Last year when I was setting up the Integration from LM to Jira.. the Test Alert Delivery was all I needed. I assumed I could get by using mainly/only it this time.
    And the Integration logs show 'failed to parse' under external ticket ID, and the log details show the entire HTTP response as: "Timeout received waiting for HTTP Response".  And to reiterate from earlier, I do not have the Include an ID provided.... checkbox checked.
  • I mean that LogicMonitor might be waiting for a different kinda response. Like try returning some basic json like {"TicketID": "12345"} and see if that times out still. Also what happens when you click on the Test Alert Delivery in LM?
    Can you show us screenshots of the test and/or the integration log?
  • Nope, I did not check that box. The rulebook I'm using either prints HELLO if the message contains that as it's value, or prints the entire payload if message != HELLO.
    So as far as I know, it's not waiting on anything. When I test using curl, there are no time outs.
  • I don't know anything about Ansible webhooks but perhaps LM is timing out because it's waiting for a specific response back? Like do you have the "Include an ID provided in HTTP response" enabled? If so, you want to include that json key into your response back.
  • Ok so I might have jumped the gun above.. so turns out removing the trailing slash now allows LM to reach the endpoint but I get a 404 returned.
    <html> <head><title>404 Not Found</eda-event-streams/title></eda-event-streams/head> <body> <center><h1>404 Not Found</eda-event-streams/h1></eda-event-streams/center> <hr><center>nginx</eda-event-streams/center> </eda-event-streams/body> </eda-event-streams/html>
    So without the slash, LM reports a 404, the endpoint a 301. With the slash endpoint reports a 200, but LM a timeout.
  • Ok well nevermind I guess, turns out the trailing / in the URL is what was breaking this.
    Ugh
