Patrick_Rouse
Product Manager
12 months agoWhat model are the Arista APs? If you don’t want to create an API-based integration with Arista CloudVision, the easiest way would be to use the CloudVision Portal to configure the SNMP and Syslog Settings so LogicMonitor can collect metrics via SNMP and send syslogs and traps to LM Logs.
An example you might refer to are the Ubiquiti UniFi AP modules we launched in 2024.
