Check if you have the snmp.community property set anywhere including at the root group level. Properties get inherited so it can be easy for some properties (especially when using the Wizard) to get set at a higher level and flow down. It's also possible that ProperySources might do a snmp check but it wouldn't be nearly that frequently.
Also if you were doing v3 previously, verify that is still working. If v3 stops working LM might attempt to downgrade to v2 and perhaps use a "public" default value.
They are all using SNMP v2
I do have snmp.community set and I have it set at the group these switches are in with the correct community string. They wouldn't be getting all the data they're getting if the string were wrong, everything in the portal looks normal to me.
