Mike_Moniz
Professor
11 months agoRather then use a scheduled SDT, you can setup static threshold that change depending on the time of day. For example you can override the 24-hour standard threshold so that between ~5-10am the thresholds are higher. For example (untested):
I haven't used dynamic thresholds much myself either.
- Kelemvor11 months ago
Professor
Yeah. That would basically turn off alerting instead of just suppressing the notifications so that'd probably be a better idea. It always starts at the same time. Too bad it doesn't always end at the same time. ;)
