jake_nahm
Product Manager
7 months agoHi billbianco ,
I would be interested in learning more about this use case. If I understood the request correctly, you would like to plot.
- The raw metrics as is
- Sum of raw metrics, per each time interval the metrics is collected over a period of time.
Seems like you were not able to use the custom graph widget to do so, and now are considering complex datapoints in a datasource, potentially using Groovy.
If you're willing, it would be great to go into more details around the areas you feel challenged.
