Lewis_Beard
Professor
4 months agoCustom Properties auto-resetting after Save?
I will probably open a support ticket and I hope this is just an ignorance thing on my part, but figured I'd check first.
A user reported a weird situation. They have a resource folder in which the...
- 4 months ago
Hey Lewis_Beard
snmp.version is actually something that is set by the collector. It's a custom property as there are situations where you have to manually define it because a device does not respond to the typical snmp discovery process. However, in 99% of situations, snmp.version will be set by the collector and it's set with a value of the version that successfully responded during the collector autoprops process for a device.
This is described here in this doc:- On an individual device, snmp.version is automatically set by LogicMonitor to the version of SNMP which responds. LogicMonitor attempts SNMP communication initially with version 3, then 2c, and finally version 1. The highest responding version is set for this value, and any attempts to edit it will automatically revert.
- If you attempt to change the SNMP version after initial device addition (by entering new credentials), you must ensure it and the pertinent credentials function. If LogicMonitor is not able to communicate using the new version specified, it will automatically revert to the original version as a result of the failure.
