4 years ago
Confusing requirements and output get_admin_list using the SDK - Guidance requested
	Hello all,
	I'm trying to gather a list of users (role agnostic) and include only a specific set of fields in my output, filtered by a last_login_on timeframe.  When I attempt to do this throug...
- Anonymous4 years ago
Here you go. This uses my lmwrapper helper script, so if you're not using that, you'd need to setup the api object manually. Just set the month, day, and year variables to the date you'd want.
from lm import lm from datetime import datetime #datetime before which to consider users inactive month = 10 day = 1 year = 2021 inactivedate = datetime(year,month,day,0,0,0) #these next few variables are for use in pagination size = 1000 offset = 0 results = [] endfound = False while not endfound: users = lm.get_admin_list(size=size, offset=offset).items #fetch a page results.extend(users) #add the fetched data to the tally offset += size #figure out the next page range endfound = len(users) < size #check to see if we fetched an incomplete page (e.g. we're done) for user in results: lastlogin = datetime.utcfromtimestamp(user.last_login_on) #convert the string to a datetime object so we can compare it to our inactivedate if lastlogin < inactivedate and user.status != 'suspended': print(f"Disabling {user.username} (id={user.id}), last login time: {lastlogin.strftime('%Y-%m-%d')}") response = lm.patch_admin_by_id(user.id, body={'status':'suspended'}) print(f"{user.username} (id={user.id}) is now {response.status}")
