acampbell78's avatar
acampbell78
3 years ago
Best Practices for removing clients from LogicMonitor
I was just wondering if there are specific steps I should follow when I need to remove specific clients from LogicMonitor. Do I need to start of with removing the devices first? Or If I remove the sp...
  • Ajay's avatar
    3 years ago
    If the goal is to completely remove a resource from your logicmonitor portal, then you can just go to the resource, hit on “Manage” and then click Delete. Make sure you then also permanently delete it from the Recently Deleted folder.
    Here is the doc for that: https://www.logicmonitor.com/support/devices/adding-managing-devices/deleting-devices
    Removing a collector only removes the collector and will not delete the devices the collector is monitoring.
    Hope that helps
