Jsewell
Neophyte
9 months agoAlert tuning help
Hi team. Hopefuly someone can point me into the right direction when it comes to disabling alert tuning at a group level. We have a group with a large number of network devices, and would like to ...
- 9 months ago
I don't believe you can. While you can override other things like thresholds, I don't think you can override alert disable. What you can try is to remove the thresholds at the root level or from the DataSource itself and instead set them just on the instances you want. That might be the easiest.
I guess another approach can be to write a script using the LM API to go thru each device and disable alerting at the instance level. Then you can manually enable the ones you want (like uplinks). You may want to also modify the datasource to also disable instances on discovery too, although that will disable data collection, not just alerting.
