Jeff_Batchelor's avatar
2 years ago
Alert on changes to Property Values
Has anyone setup a datasource that would send out an alert if specific properties change their value?
A request from our network team is around triggering an alert when the firmware on some devices changes.  This is being populated into a property for the device but need a way to trigger an alert when its value changes.
We are migrating from Solarwinds and it seems like this was an ability Solarwinds could alert on.
    Müller_N wrote:
    Use a script datasource, get the data out of the device property with the
    usual hostProperties groovy line like:
    firmware_vers = hostProps.get("auto.entphysical.firmwarerev")
    Remove any NaN characters or create something like a hash sum and convert it to an integer so LogicMonitor can store it in a datapoint.
    Then use the one of the numerous delta functions as a threshold:
    Does not sound particularly difficult to me.
    This is the right way to do it.
  • Use a script datasource, get the data out of the device property with the
  • I'm not aware of a way to alert on a property change directly, but you can create a ConfigSource (if there isn't one already) that contains the firmware version so LM can alert on it changing that way.
    • Jeff_Batchelor's avatar
      Jeff_Batchelor
      I will look to see about trying to do it this way as it does seem like the only possible solution that doesn't involve a lot of work scripting out a way to read a custom property out into a different custom property and then comparing it to the old one on some basis.
