Matt_Whitney's avatar
9 months ago
Topology Mapping - Edge connection alert status
In the current topology mapping, the device-level nodes will light up red/orange/yellow depending on what the highest severity alert is on that device.
My feature request is to give us the option to show the status of the individual connections. So show the connection lines as green if they are healthy/connected, but if the interface or BGP peer is down then the connection should be red based on the alert status of the connected instance.
Would also like more control over which alerts cause the mapping nodes/edges to light up. For example I might only want the NODE to light up if there is an alert for HostStatus, but if there is an alert for BGP or an Interface then I might want the edge to light up instead. That way I could get a great idea of what was going on just by looking at the map.
1 Reply
  • skydonnell's avatar
    skydonnell
    Hey Matt!
    Great insights and suggestions for the topology mapping! I have submitted your feedback to our product team for review!
