thanjalot's avatar
10 years ago
Warning before Alerting is disabled at very top level
Hi
After an incident yesterday when a new starter inadvertently switched off the alerting at the very top level of our portal, I was wondering if either the 2 following features can be implemented:
1. deactivate the Alerting toggle at the very top level (i do not see ant scenario where i would want to stop alerting to 4000 devices)
2. have a warning such as "You are about to turn of monitoring to 4000 devices - are you sure? YES/NO"
We have already decided to move new starter into a more restricted account, however i find it surprising how easy it is to turn of alerting at the global level.
Thanks
Thanjalo
1 Reply
  • 14 minutes ago, thanjalot said:
    Hi
    1. deactivate the Alerting toggle at the very top level (i do not see any scenario where i would want to stop alerting to 4000 devices)
    Thanks
    Thanjalo
