Andrew_McAllist's avatar
13 years ago
Queries - ability to save and create reports, searches and dashboards using same simple queries.
Like private and public dashboards,
1. Ability to save custom search queries for private or public use.
2. Use same queries to generate reports, Dashboards or search results on Alert Dashboard. Similar to how Sumo Logic queries work.
A basic search syntax that uses logical and familiar operators allowing you to create ad hoc queries quickly and efficiently. The Drop down menu driven queries are a challenge at times.
Logic similar to customizing \'\'Applies to\'\' would work.
Best,
Andrew
