Bennett_Borofka's avatar
Bennett_Borofka
Former Employee
9 years ago
PropertySource - ConnectWise_ConfigID
PropertySource to retrieve the ID of a matching Configuration (CI) in ConnectWise.
Quote
This PropertySource uses the auto.entPhysicalSerialNum Device property (set by Cisco_Product_Info PropertySource) to query a ConnectWise site (instance) to find a matching Configuration ID. You can override the auto.entPhysicalSerialNum property with a manually-applied physicalSerialNum property.
A matching Configuration ID is saved as a Device property, auto.connectwise.configid.
Required properties:
auto.entPhysicalSerialNum or physicalSerialNum
connectwise.companysite
connectwise.companyloginid
connectwise.public.key
connectwise.private.key
These 4 properties can be found from ConnectWise's API documentation:
https://developer.connectwise.com/
LM Locator: YR77GF
1 Reply
