James_Cornman's avatar
14 years ago
Network Interface duplex monitoring
When our customers reboot or change OSes on their machines, its common for a duplex issue to arise. I\'m looking for a way to monitor that, as well as have a sense of change management with it. Can a graph be created to monitor this setting for network interfaces?
  • James,n
    nCould you engage us via email or chat? Its helpful when making datasource changes to have a specific host or set of hosts in mind. (Usually once we get it working for a few, itll work for more general cases as well)
  • James, what type of device would you like to monitor this on? Typically when there is a duplex mismatch you will start to see interface errors which we do monitor and alert on. If you would like to know if a duplex configuration has changed on a switch interface we will have to investigate.
