Brian_Hoban's avatar
8 years ago
Need Token for Device ID to be able to pass to Alerts
All,
Although LogicMonitor provides a key identifier in the Device Resource called "id" https://www.logicmonitor.com/support/rest-api-developers-guide/devices/about-the-device-resource/ , it doesn't provide a mechanism to actually reference that key identifier via a token. https://www.logicmonitor.com/support/settings/logicmodules/tokens-available-in-datasource-alert-messages/
Can you please either create a token for the device id's or expose the device id as a system property of the device?
1 Reply
  • Sarah_Terry's avatar
    Sarah_Terry
    Hi Brian - We're looking into the best way to expose device id (this applies to other resources as well, e.g. instances).  One idea is to expose id as a property for the device, which would allow you to reference it as a token.
